Pairing issues
Lloydevans
I have a Wi-Fi switched fused spur used to control an Aga. I have previously had it linked to my BT router but can not get it to pair with the EE router. I have temporary turned off 5ghz but this has made no difference.
i have managed to pair all other devices to the router
Is there anything I can do to over come this?
Thanks,
lloyd
@Lloydevans  You should have someway to factory reset the spur.  If you don’t have the manual for the product you will probably find them via a google search.
I know how to reset the switch, however, once reset it will not pair it just times out
@Lloydevans  As well as temporarily turning the 5Ghz band off, depending on the router it will either have an option to go to WiFi5 or a Mode option - or maybe even both - give them a try.
Let us know how you get on.
SamL2
Hi I have just moved to EE - I am having the same issue as you - did you get a solution please. I have 2 wifi spurs which control my lights. I managed to get my smart plugs to work. Grteful for any advice.
I am having the same issue - I have a new Smarthub pro - can you advise how I change to wifi5 or a mode option - I cant see this in the hub manager thanks
