Order not completing - stuck on ‘order pending’
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-11-2024 06:38 PM
Hi, I’m a new broadband customer to EE but I’ve been a mobile customer since the start of the year. I’ve never had any problems, however when I switched over from Sky I was told my activation would be the 30th Oct with a text and email to prove. Nothing was activated and I was then told the 4th by a text message. On the 5th of November, I was finally connected when I had to call to figure out what was going wrong - no landline. I’m using my own landline phones, but that shouldn’t make a difference. My order is ‘pending’ on my EE app, and I cannot set up any WiFi controls. I had called every number I was given and was told different days for it all to be done. On the 5th a complaint what opened and was supposed to be dealt with by the end of today (8th) but upon calling up EE/BT again as I was confused why I was sent a second smart hub (they have no idea why either and told me to leave it alone), they told me that the complaint is due to be resolved on Tuesday the 12th? Surely it shouldn’t all be a lengthy process considering it’s called the ‘One touch switch’?
Anyway, has anyone else had this problem and knows how to solve it? I wouldn’t be so bothered about landline but there is someone here who depends on it to receive calls from doctors, hospitals etc. any help would be appreciated! Thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-11-2024 07:36 AM
@LettuceLeafy Just to let you know, the picture is still waiting clearance, might be something that shows and not liked, but when it does get cleared will take a look.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-11-2024 09:34 AM
Okay thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-11-2024 08:06 PM - edited 09-11-2024 08:08 PM
@LettuceLeafy Your picture is up now, only thing that stands out, and not even sure if the hub is correct because you just have to see if it corrects, but it says that the DVA is out of reach from the router. Will post the light status of the adapter when i find on another posting that i did.
What your Digital Voice
Adapter light means
1 On initial plug in – flashes 0.5 seconds on,
2 seconds off
2 During registration – flashes quickly
0.5 seconds on, 0.5 seconds off
3 Once registered – stays solid green
4 During a call – flashes slowly 1 second on,
1 second off
5 Once registered, if there’s a connection
problem with your broadband – flashes
0.5 seconds on and 2 seconds off.
Maximum Digital
Voice devices
You can register a maximum of 5 Digital Voice
devices (that includes Digital Voice Handsets
or Digital Voice Adapters) to your new Hub at
one time
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-11-2024 08:43 PM
The Adapter is a solid green light, but I have taken the phone out of that and put it straight in to the back of the hub. Everything seems to be working now so fingers crossed it stays that way. The image I uploaded still all says the same, not sure why as I’m not using the adapter now. Only thing is that the order is still stuck on processing but hopefully that will sort itself out without cutting anything off again. Thank you so much for your help I really appreciate it
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-11-2024 08:47 PM - edited 09-11-2024 08:51 PM
@LettuceLeafy What the router say's may not be what it means, chocolate and fireguards are just two off the words that can be used for description. Glad you have some success, you could move the DVA closer to see if the message does change, but only if you can be bothered...👍👍
Think once you register the adapter, then stays on the system until you de-register, max 5 allowed DECT devices attached.
If you order does not clear, then you may have to chase up, EE could still be doing some work in the background and until finished then order will be open!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-11-2024 10:16 PM
Turns out the good news didn’t last - The landline will only receive calls from EE network numbers and it calls out fine, any other incoming calls from a different network says “the number you have dialled is not recognised”. I have a callback Monday afternoon to re-port the phone line to see if that fixes it. Regarding the DVA, it is plugged in right next to the Hub, I have a second DVA that I could test out if I ever need to but hopefully keeping it plugged straight in to the back of the Hub will work. I also should have mentioned I had received an email to say the order was complete, so I’m just assuming it’s a delay in the info updating on my account. I’m still a bit confused as to why the account number says it is registered to another account, or is that just a generic error message that could also mean that it’s already linked to my account?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-11-2024 10:21 AM
@LettuceLeafy Sorry, missed the account number question you posted, it is possible you answered it yourself. you know the account number for the BB, and if your BB and Mobile look ok and you see both when you login to your account with your EE ID then it may just be so, if not then it will be a call to EE CS to find out what is going on. On my home screen see both mobile and broadband, so they are both linked ok, web and app.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-11-2024 12:37 PM
Okay thanks. I’ll update after the callback tomorrow afternoon to see if anything has been fixed
- « Previous
- 1
- 2
- Next »
- EE order went nowhere in Broadband & Landline
- broadband in Broadband & Landline
- EE Broadband not Live after BT Fibre install ‘Order Pending’ in Broadband & Landline
- Order pending for six months in Broadband & Landline
- Ordered 5G router with sim, paid up front, order cancelled no refund in Mobile Broadband
