Openreach ONT Speedtest of 1.6gbs
Bluenose_Dave
Recently having the new EE 1.6gb/s service went live Openreach engineer said he will come and check the speeds at the ONT as EE smart hubs LANs ports are only 1gb/s,
so he come with his openreach laptop, but his laptop has only a 1gb/s Ethernet port, so any one having this service, ( make sure you have something that can connect over a 2.5gb/s LAN or buy a usb3/c to 2.5gb multigig adapter i got one coming later this week to test it myself from my end of things )
had to go via WiFi speed as it was 980gb/s it was classed as on the 1.6gb/s speeds, now my order is complete when EE call me tomorrow i will ask them to check speeds via their system
FFTP Busiest Home Bundle 1.6Gb,
Smart hub Pro and 3 backhauled smart WiFi Pro extenders
WiFi 7 devices iPhone 16 Pro Max
7 REPLIES 7
MrCook3
Forgive me, but why would you order a 1.6gbps service if you don't have devices capable of receiving those speeds?
Bluenose_Dave
As only went live Friday after 6 weeks of loss of service, so once openreach have got the service up and running, now i will upgrade router and the switches to support the new speeds
Ah okay, that makes more sense!
Hopefully it's smooth sailing for you, I'm definitely interested in the 1.6gbps package but don't think it's possible to upgrade yet.
Bluenose_Dave
I hope so, as it been a nightmare i was one of the few that moved from BT too EE, i was on BT 900/110, but when they changed me over i lost the connection, and had weeks of openreach not doing much to resolve it, another factor with the speeds was it worked about about £10 more with the prices at EE to get the 1.6gb/s
It future proofs your internet, 12 months from now IT hardware and Tech devices will be manufactured to support the faster speeds
Hi Same boat now. They had to close my old EE broadband account down (from BT) and setup a new one as I was on fibre 900 but that's the only way they could trigger the new 1.6gbps package. Did they provide you a new ONT as my current one is gigabit only. If so what model ONT did they give you? Are you able to send a pic. I am looking forward to the new speeds. I have a firewalla gold SE (2.5gb capable) and a home server with a 2.5Gb nic. I'm just trying to find out as much info as I can about how smooth the install will go. Some people say its just a replacement ONT and should be good to go.
timprocter
@AmIBeingObtuse
This is the ONT they provide mate.👍
Full Fibre Busiest Home Bundle 1.6Gb.
