05-09-2023 11:15 PM
The last 3 days we had very little Access to our home WiFi, we can't find out if a problem in our area as just told to talk to community!
So anyone else experiencing no WiFi in Exeter/crediton area??
Also I'm able to get a credit for the lack of service, because I pay enough for the privilege, and lost 3 days of it?
05-09-2023 11:19 PM - edited 05-09-2023 11:21 PM
BB issues are rarely localised but specific to your own line.
If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
If there's any compensation for lack of service, it'll be auto calculated from when you report it.
05-09-2023 11:21 PM
