15-11-2025 10:31 AM
I had a power cut to my home only and when we got power back everything is back on but my router is no longer outputting a wifi signal. Router is displaying solid blue light, I’ve tried restarting the router, resetting the router, resetting the open reach box but still no wifi detected on any device. Any recommendations?
15-11-2025 12:12 PM
Hi @Bozzy1994
Did you leave the router to connect to the internet first becase if power cut was more widespread it may impact the connection to your home which in turn means no internet. When you search for WiFi networks is your network visible.
If this fails then you'll need to speak to EE CS on 150 about a replacement.
15-11-2025 12:12 PM
Hi @Bozzy1994
