03-09-2024 01:19 PM - edited 03-09-2024 01:20 PM
New EE's Full Fibre BB (FTTP) only running at max 950mb ? Should be 1.6 Gbps !
I had my new install today and its only running at max 950mb down and 115 up and it should be 1.6gbps
I have the new EE SMART Hub ! Can someone advise ? I have Cat 8 Cable connected to the Yellow Ethernet ports.
Does it matter what port you put it in as its not got any label or marks to say otherwise. please advise as I am paying £25 more to get these faster speeds that I don't currently get.
03-09-2024 10:33 PM
You need to set up a connection profile with pppoe that used the network card - it won’t just work with auto detect set on.
03-09-2024 10:36 PM
Just did Wi-Fi test on my phone and it goes over 1400 mbps and 110 up so that confirms the speeds are working as it should and I need to update to a better router for 2.5g Lan ports/
03-09-2024 10:56 PM
What speed test service are you using? Fast tends to vary to much and Speedtest and NPerf suffer from too many users so under report. I set up a local speed test server on my server because they’re all wildly unreliable.
WiFi 7 Local Speed Test 2426.8Mbps down)
Wifi 7 Speed Test (1831Mbps down)
WiFi 6E Speed Test - 1 floor up (1215Mbps down)
04-09-2024 01:34 AM
What speed is the port, if only 1 gigabit it won't handle the 1.6 gig speeds.
If you have a new install at 1.6 gig I would have expected EE to provide a modem / router with 2.5 gig ports.
Guess you'll have to contact EE directly when they open Wednesday.
Bert
04-09-2024 01:36 AM
Bit confused Xray, if input is 1 gig, how can he get 1.6 gig over wifi? OK device to device over AX wifi or better I guess.
04-09-2024 02:43 AM
@Bert007 : Who said input is only 1 Gig? The OP is on a 1.6 Gig plan, has a 2.5 Gig ONT & is getting 1.4 Gig over speedtests.
04-09-2024 10:57 AM
@XRaySpeX I think the point was teh op only has a 1Gb WAN port connected to the ONT so how was 1.4 possible?
04-09-2024 11:08 AM
The port you plug the ONT into is multi-gig the rest are 1Gb 😂
04-09-2024 02:50 PM
No, @cliffy37 , the OP has the Red WAN port connected to the ONT. That port is rated at 2.5 Gig.
In my original reply to the OP I was answering the OP's original query about the Yellow LAN ports. If I thought this far ahead that my reply wouldn't be read in context, perhaps I should've put 'LAN' in my reply.
04-09-2024 05:45 PM
@XRaySpeX I thought the Op had reverted back to the original EE Smarthub while they wait for there WiFi 7 router to arrive
