28-04-2024 10:07 AM
My router keeps going solid orange at certain times if the day. It was placed in the correct position by the ee engineer. Why does this hapoen. It seems to start at about 11 pm and continues into early morning. Help please
28-04-2024 12:43 PM
Which router?
28-04-2024 12:43 PM
Which router?
28-04-2024 01:52 PM
Wifi plus
28-04-2024 01:56 PM
Sorry, that's not the name of any router. Do you mean Smart Hub Plus? Otherwise read its label or post a pix.
28-04-2024 02:01 PM
this is what goes orange. I'm nit very technical sorry
28-04-2024 02:07 PM
That's not a router but a WiFi Extender. Try moving it closer to the router.
28-04-2024 02:16 PM
Will do thanks
28-04-2024 02:17 PM
Thanks! You're welcome 🙂 ! Glad I could be of assistance & hope it soon gets sorted.
28-04-2024 02:31 PM
Just a thought why does it go orange at certain times i. e. 11 pm but during the day its ok?
28-04-2024 03:36 PM - edited 28-04-2024 03:37 PM
@Beyond1 Have you used the APP and set the extender into a group, and then have it set to disable at the preset time?
You may have to check the app settings if you have possibly done this by mistake. Link below if you need it.
