05-12-2023 09:30 PM
I have recently moved from BT to EE for broadband and digital voice. Although EE sent me a new router and smart wifi devices, I have retained my original BT Advanced Digital Home Phones with Alexa.
I've re-registered these phones to the new router, and so they are working to both make and receive calls.
However, the Alexa function is not working: when I press the Alexa button, or try to access Alexa Settings from the phone's main menu, I see "Alexa is not available" on the phone's display.
Anyone else experienced this issue or know of a solution, please?
08-12-2023 06:06 PM
@Storm500 But why would that be the case? There must be something about the EE router that "gets in the way". What can that be, if not closed ports?
08-12-2023 06:51 PM - edited 08-12-2023 06:53 PM
There’s a lot of posts on the BT community about using and setting up third party routers with digital voice and the BT Hub has to be first to pick up digital voice as the third party router won’t pass digital voice through. They also give information on how to setup the BT first with the third party router second.
Your case is different as you have effectively 2 BT routers so which ever one you have first takes digital voice and won’t pass it through to the second. Digital voice is BT’s proprietary version of VOIP and for security the BT/EE routers don’t allow digital voice to pass through. So you will have to choose which router to use.
11-12-2023 01:01 AM
The plot thickens. My complaint handler at BT/EE escalated the Alexa issue and has heard back from senior managers who (a) didn't know or expect the Smart Hub Plus to be incompatible with Alexa on the phones; and (b) are not aware of any issues arising with this service.
The complaint handler is investigating further and will contact me again on Wednesday, but it's interesting to have this feedback along with that of EE on Twitter, which claims the Smart Hub Plus is incompatible with the phones' Alexa functionality, and the 150 support agents who claim that it should be working, and advise me to phone Amazon!
11-12-2023 07:27 AM
11-12-2023 07:34 AM
@AML4 Thanks for the update mate.
I'm in the same position with Alexa, and am getting mixed messages from EE. Some of the team there say they are getting a lot of calls about this but their "workflows" don't include a solution, and I should contact Amazon; others, including the EE staff in this forum and on Twitter, say the handsets are not compatible with the Hub, Alexa won't work, and there are no plans to make it work; and the Executive Complaints team says that senior managers are unaware of a problem and believe it should work!
In due a call from Executive Complaints again on Wednesday with a further update...
16-01-2024 10:59 AM
I have the same problem as the one you've described above, my BT dect handsets no longer work for voice with my new EE hub.
I can see that the fix is to use your BT Hub as well, but I've sent that back to BT at their request.
Any idea if there is there anything else I can do to fix the situation?
21-01-2024 11:12 PM
I have spoken to BT support re Alexa not working with the EE Smart Hub Plus towards the end of last year having had weeks where the BT handset just didn't work, (it does say on the box that the phone only works with BT Hub2 but with the new relationship BT/EE you could expect compatibility with the EE hub), and there was an EE 'relationship' engineer in their office at the time and they said Alexa was planned to be working with the EE hub sometime in February 2024. It took quite a few weeks before EE got the BT phones working properly.
22-01-2024 09:54 AM
12-02-2024 02:51 PM
I have the same situation, apparently EE do not have a licence for Alexa, even though they are now part of BT, you would think that BT would have included this in the cooperation and ensured the Digital Voice Service was maintained for the benefit of those using it.
12-02-2024 10:23 PM
@garywood84 : Are you plugging your BT Advanced Digital Home Phones with Alexa base station into the phone socket on the router or the adapter, or are you using it over DECT to connect with the router's inbuilt DECT base station?
