17-01-2025 01:47 AM
I've seen a few threads taking about this but it seems that they've never been resolved. I game using PS5/XBox and since upgrading from BT to EE have been hit with the above problem.
The XBox will display 'moderate NAT UPNP not successful'. If you run the 'Test NAT' a few times it switches to open. So far so good. But the moment you load up an online game, when the runner meets the road, after connecting with Internet services the game, let's say Black Ops 6, displays a moderate NAT (found under Network/ Network Info when in multiplayer) Settings, then going back to the NAT submenu the NAT shows up as a moderate NAT again. It never switches from moderate in game, incidentally. Not once.
The PS5 is absolutely stuck on TYPE 2 - moderate NAT. Nothing will fix it - even temporarily, only on one screen.
I've tried Pinholes, I've tried a static address and port forwarding, I've tried DMZ (though you can only use one device with that so it's relatively narrow as fixes go) : nothing changes it. I haven't had a problem with NAT restriction for near enough a decade.
It might be worth mentioning that on switching on the XBox it takes significantly more time to connect, using a wired connection no less, for the XBox to connect through the router to the Internet. Again this problem only exists on the new router.
So my obvious question is: is this, as others suggest, a firmware issue? Or is this a problem that can't be fixed. Because honestly this is a deal breaker for me. A restricted NAT affects who you can matchmake with, how long it will take - as a result - to find a game, whether certain services work as intended. This simply isn't good enough and I'm honestly desperate for some sort of solution.
16-06-2025 03:02 PM
My Xbox takes an "age" to connect and gives a moderate NAT type and unsuccessful UPnP connection. It seems port forwarding doesn't work so no point in trying that. It would be nice if they acknowledged the issue as it's not fit for purpose if your purpose is Xbox or Playstation gaming, or cameras... Regretfully I have disposed of my old router so a new one is on the way.
16-06-2025 05:47 PM
Can confirm UPnP personally never worked on an Xbox for me either on the EE SH Pro, however it did not seem to cause any issues for any of the gaming devices in the household despite a moderate NAT.
Still offered a better experience overall than the BT SH2 did, but that is entirely anecdotal.
16-06-2025 08:07 PM - edited 16-06-2025 08:28 PM
@Interloper68 What hub are you using, had all the port fwd working on the Smarthub+ for the daughter on her PS5 and she has everything under the sun not that i know anything that she does, but it's an alien from outer space when all the gear is on wands, stick's, visor's, mic's, ear pods, funny to watch though.... Never complained once about any issues.
PS5 wireless connected through Asus RP-AX58 to XT8 in AI wireless mesh
17-06-2025 12:29 AM
The latest from EE, until tomorrow I hope.
18-06-2025 05:32 PM
UPnP not working *is* an acknowledged issue as far as I know. Glimmer of hope though: one of the Smart Hub Plus devices I oversee was updated to firmware 3.8.11 the other day and UPnP seems to be working from what I can tell.
21-06-2025 04:05 PM
After a nicer call to customer service and a guy called Tom it turns out I had been sent the wrong router, which i'm told is common for "legacy" customers switching over. Spoke to him Wednesday, new router arrived this morning so can't fault them there. Slightly smaller and with a perforated skirt, this one also has a phone socket on back so no need for the plug socket type anymore. Switched it on and my Xbox instantly connected, NAT open and I'm assuming UPnP is now working as intended. Night and day with my call centre experiences, first told nothing wrong with router and things take time to warm up etc, gaslighted by a manager also. I had mentioned that there was much on the forums about the subject so that may have helped with the follow up, but regardless they delivered and resolved my issue.
21-06-2025 04:56 PM
@Interloper68 One way to sort it out, more equivalent to what you had with a wi-fi 5 router. Link should you need to anything else that is compatible with the older Router.
30-06-2025 06:08 PM
So which router were you originally sent and which one did you get resent to you ?
02-07-2025 05:32 PM
I've just posted in another thread that the latest firmware for SH31B seems to have fixed UPnP (3.8.11). It wasn't working prior to this.
05-09-2025 08:13 PM
I have this exact issue with my XBSX. All of the same problems with the EE Pro hub on 1.6Gbps bb.l
-Turning xbox on, takes 20 seconds or so to connect online
-Network settings on XBSX show uPnP not available and NAT: Moderate
- NAT test a few times changes it to Open in game NAT settings show Moderate
-Issues Matchmaking or joining friends games.
**Additional issues**
- Webpages on my phone, tablets etc take up to 10 seconds to load... Youtube videos the same with buffering here and there...
-Router > My network doesn't show all devices i know to be connected, and even "Show Disconnected" filter shows 0 on all ports / wifi bands. The EE app > manage network i can see every device connected or not. Very frustrating and I have seen nothing but the same issues repeated across the board. Blatantly an issue with the router but EE don't seem to be acknowledging? I could be wrong.
Had ZERO issues on my old 900mb BT Smarthub 2... xbox always connected to Internet even when it was powered off / in sleep, which was handy for remote installs etc. Now I cant do that because it seems as soon as its turned off, the router disconnects it.
My XBSX has been set to DMZ and I have a DDNS setup for servers but that shouldn't be causing issues as I had it the same on my old router.
If i plug in my old router, it works just fine.. EE, Please sort this out
