Migrated to EE Broadband, when will I get my new hub?
hostler
Recently migrated from BT FTTC to EE FTTC Service.
I’ve had the emails that the migration is complete, using my existing BT hub, and the service is live.
When will my new EE hub arrive?
11 REPLIES 11
hostler
Good tip! Thanks.
No DV and no need for it either.
Sent from my iPhone
@hostler Unless you have devices that work better on wi-fi 6 compared to wi-fi 5 then do not expect miracles, if anything it goes the other way and older devices have way more problems getting on to the newer EE router, just use the compatible wi-fi feature if you hit problems. The speed uplift is very little between the 2, and with a fttc connection then that is all you get over the internet wise, but to a wi-fi 6 device it will be slightly quicker device to router.
