Mesh WiFi Hub
bradshawj
I’ve just switched from BT Broadband to EE.
Previously, I had a BT Router and a Black Disc which created a mesh network.
I now have a Smart Hub (SH31B) and have a white Smart WiFi extender (SW10A) which I assumed would do the same as my old BT disc.
I can’t connect the SW10A so am wondering if the 2 bits of kit I have are incompatible?
Smart WiFi Plus is its marketing name. It looks near identical to the SW10A with slightly different orientation of buttons etc. on the back.
I doubt many are in circulation.
bobpullen
Not compatible. You would need an SW30A.
Did EE send you the SW10A as part of the switch? If so, they shouldn't have done 😕
Thanks so much!
No, picked it up on ebay for £50 - no real issue as I can stick it back on there and get my money back.
The SW30A - does that go by any other name or anything as I'm struggling to locate one?
bradshawj
Thanks for the help!
