Landline retention - VOIP doesn't work
pcwood
I live in a rural area (actually in a  wood). I have copper wires (laid through the wood from fibre off a road) for my broadband and landline. My EE contract is up in June and I believe that I will not be able to continue with my landline. Upon checking with EE staff in one of your shops, they stated because my house does not have fibre broadband, the VOIP option would not work over the existing copper wires, unless fibre is laid to the house.
There are two issues with this - firstly, we can't get a mobile signal at home (I receive calls on my mobile via Wi Fi, and the quality of calls isn't brilliant and doesn't always work ), and secondly, we're prone to power cuts. The last big one (storm Arwen) lasted for 5 days. We were only able to contact the electric company via the landline (we were waiting for two hours on a call, so couldn't hang around taking or waiting for a call some way away  from the cottage).
Not having an analogue landline is therefore a problem for us - we will have to buy another new smart phone that we don't need at present (we currently use one between us), and during a power cut will find it difficult to contact the electricity  provider (as the Wi Fi calling won't work - the other option is to tramp 400 yards away to get a signal possibly in a raging storm).
Is it physically impossible for us to keep our existing landline, or are EE and other suppliers just making things difficult for customers like me (and I appreciate there must be very few in our position)?
I hope this is clear - sorry for the length!
15 REPLIES 15
Brilliant Contributor
@pcwood In your first paragraph, VOIP can and does work over copper, has done for many many years. The main problem is new contracts with ISP's now OR are making changes which push the landline to operate from the Ethernet VOIP structure rather than the old PSTN network. This is now pushed back to 2027 from OR, but if your exchange is one for change then there may not be the option. Not sure if you leave everything alone that they can force the change on you, but if you do re-negotiate for price etc, then you will pushed down that path. Checking the OR wholesale site BT Broadband (btwholesale.com) with your number or address will let you know. If you know what your service is but does sound like you may be on a fttc as you mention fibre/copper supply. And don't listen to what the shop staff tell you, its good you have asked the question. HTH
And if you do not get a mobile signal, that should be the first red flag to any isp about making you go to digital voip.
pcwood
Thanks JimM11 - when I went onto EE to look at the contract renewal options, it was made quite clear that I couldn't have a landline (I think I had to tick a box to confirm that I understood this). I left it, and am tempted to leave it and see what happens. BTW, this is what I got from the BT wholesale site - double dutch to me!
FTTP is not available.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
@pcwood There is something wrong in the renewal process, i would look closely at this, with an existing telephone that you have it must be with EE, they cannot force you to drop this option. have a look at the table from OR link again, Below is my option the table with WBC SOGEA is the killer, means they want to kill your landline and force it over digital which you don't want..... RED flag is you have no other means of communication when the power is out........
45.43510.3632.4UnavailableAvailable
44.132105.427.2UnavailableAvailable
Thanks - the existing  landline is with EE, and I've just been on the site to look at renewal options again and it's stating the landline will be withdrawn.
I've written to them, stating my position (I'm a pensioner too), as I want them to put something in writing.
Cheers
Paul
Mustrum
@pcwood  An EE shop may not be the best place to get broadband advice, and your story highlights this.
@JimM11  you are not quite right with what you say. Since September last year and the stop sell with analogue and other products, SOGEA just means new analogue products are not available, however existing contracts may be extendable.
There are also lots of false stories re Digital Voice - which by the way is just BT/EE proprietary nave for their VOIP solution.
@pcwood  could you post the rest of the BTW table which will help us give you better advice?
These BB contracts don't just end nor need renewing, just the min. term expires. They are not fixed term contracts. After the min. term they just carry on at the non-discounted price on a rolling 14-days' notice basis until you explicitly migrate, cancel or upgrade.
If you don't cancel what you have now, which is FTTC BB + analogue landline, nothing will change until nearer 2027.
Please would you post the table that goes with the BTw Availability Checker.
Mustrum
Thanks @pcwood  the table shows two things:
1. Your speeds are much slower than they should be - do you have a filtered master socket?
2. You could easily get digital voice but given your circumstances should ensure you get battery back up for the router and phone where not plugged into the router.
What is the price difference between your out of contract price and the renewal offer?
Mustrum
Thanks - this is a picture of the socket - filtered or not? The speed is around 30-40 mb, enough for streaming etc and pretty much as advertised. IMG_3086.jpeg
Agree re battery back up if I can keep the phone.
Current cost is £32 (inc £5 discount) per month, inc landline, offer without landline is £29. So I'm guessing it'll be £37 per month going forward if I leave it?
