Issue with iPhone and DNS issue with smart hub pro
UkzVortex98
I’ve been having issues With my iPhone 12 and it’s connectivity to the smart hub pro saying because they DNS is not in encrypted does not accept encrypted DNS it has a hard time searching the web
A E KING
Maestro
Maestro
UkzVortex98
Issue with smart hub pro as you can't change DNs to 8.8.8.8 you after use BT DNs what never work and you can set DDNS never fine good what work or what is safe
A E KING
@UkzVortex98 You can change it on the iPhone! Would use 1.1.1.1 and 1.0.0.1 for cloudflare also as a test if needed.
I also assume that you know the reason why EE wish you to use there DNS server.
