15-07-2026 11:41 AM
So I have port forwarded many times before with different isps for game servers tried both ark port 7777/7778 and Palworld 8211 however now that I am with EE I just can’t seem to get it working.
I have set my port forwarding rules checked that my server is setup correctly and can see they all should be working.
I have the Smart Hub 7 Pro running
Firmware version
r3.8.26-R-1595999-PROD-1
has anyone had any luck as this is a new contract and would really like to just get it working rather then cancelling and moving to another isp
16-07-2026 01:43 PM
16-07-2026 01:50 PM
Yes, EE does not employ CGNAT on fixed Home BB.
16-07-2026 01:52 PM
Yeah so it must be the router that is causing the issues, i have checked my firewall settings and even turned my firewall off entirely yet still unable to connect and get a connection timeout error
16-07-2026 05:42 PM
@FadeLupae What happens if you put the server IP in the DMZ settings on the EE Pro Hub?
16-07-2026 07:49 PM
Will try that now and report back shortly !
16-07-2026 07:58 PM
@FadeLupae Also have a check with your windows PC Network profile if set to Public/Private state.
16-07-2026 08:02 PM
@JimM11 Just set in DMZ and made sure my device was on private but still getting the same issue 😞
16-07-2026 08:09 PM
@FadeLupae Did you reboot the Pro hub after applying the DMZ IP?
16-07-2026 08:53 PM
@JimNo Given it a reboot and still unable to its strange its only got an issue with palworld.
Tried joining other game servers and they work just fine
16-07-2026 09:01 PM
Just cannot host my own servers
But palworld give a connection error IP change or not found for every server
While ark only gives it on my server and not other servers
