31-10-2024 06:27 AM
I have a new hub but it's showing firmware v0.43.01.15019-BT? Should this not be an ee firmware? I cannot get Wi-Fi controls to work
31-10-2024 10:25 AM
Without the Wifi Controls you can't run the speed test or see what devices are connected. Through the BT app I used this
31-10-2024 10:57 AM
31-10-2024 03:31 PM
Just had an update BT are now sending me out a SmartHub Plus ....... hoping this will work now with the Wifi Controls. Been told that its a stronger signal too.
31-10-2024 06:21 PM
@sbarker555 Are you a new BT-EE migration customer? The EE app does work with the EE Smarthub+, cannot comment regarding stronger/weaker signal, and will be faster speed wise as 1 generation of wifi later, but that all depends on your device capabilities, nothing else.
01-11-2024 09:28 AM
Yes I was on BT Fibre 2 and now migrated to EE Fiber 500 Essentials - was actually cheaper than what I was paying before ! I was told that the BT repeater discs I have won't work with the EE Smarthub+ so hence my original signal query. Hoping this resolves my issue on trying to pair the EE app with the hub for the wifi-controls. Due to be delivered tomorrow so time will tell then !
01-11-2024 09:40 AM
@sbarker555 When you have time, post up what BT Repeater disk's you have, the Black complete wifi DO NOT work with the EE Smarthub+, the white BT Whole Home are supposed to but some have been posted as causing issues. Link below lets you see what from the BT Forum.
What disc do I have? BT Complete Wi-Fi or BT Whole... - BT Community
01-11-2024 10:40 AM
I have the black complete Wifi, so yes this won't work then for sure
01-11-2024 10:45 AM
@sbarker555 They will not work with the router, equivalent from EE is the model SW30A to work with the SH31B/32B.
