31-08-2025 11:17 PM
Hello my Internet is not working
01-09-2025 02:37 AM
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area.
01-09-2025 07:24 AM
If it is not an area fault, I would double check all the cables are where they should be and turn off your HUB for 5 minutes and back on again, your ONT as well if you are full fibre. Failing that I would call customer care when they open and have them look into it.
