Internet connection problems in Bradford
GDPR84
Is anyone experiencing Internet problems in Bradford, West Yorkshire?
Maestro
Maestro
@GDPR84 If you are an app user then try the service checker.
Broadband Help | EE
BB issues are rarely widespread but specific to your own line.
If it is a neighbourhood issue, you could consult Check service in your area  to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
Which EE router & WiFi extenders, if any, do you have (read label or post a pix)? What is the name of the EE BB plan are you on including its speed?
