19-05-2022 11:52 AM
I changed after 20 years from BT to EE on 25th April, 2022.
I moved the router position .5m towards the office corner and approximately .5m higher onto a fixed shelf away for the old BT temporary position.
The old BT Home Hub worked very well and reached all of the rooms in the house to varying degrees, but reliably.
The new EE hub, which I understand is the same as the latest BT hub, has consistently lost contact with my iPhone SE iOS 15.1 in my bedroom. I have just tried the connection with a Samsung tablet and there is a very weak signal which, to me, indicates that the connection would be no better throughout the day and night.
I am constantly having get out of bed, sometimes in the early hours, and walk out onto the landing to reconnect, only for it to drop out again, sometimes within minutes.
The router is in my office downstairs so checking the router status is impractical.
I have successfully reinstalled the old BT router and will find out if it still drops out.
Watch this space.
19-05-2022 12:27 PM
Hi @NeilSalf and welcome to the forum.
Which router have EE provided, and which BT one do you have?
Just wondering if your issues are a result of the new router not being able to split the 2.4 and 5Ghz Wi-Fi bands?
Have you entered your EE username and password in the BT router or left it as the standard BT one?
Also why move the router, is it any better or worse in the new position?
19-05-2022 01:09 PM
I have simply reconnected the old BT router and it connected automatically. I did not need to enter a username/password.
I am going to test the old BT router connection in my bedroom over the next couple of nights
19-05-2022 01:13 PM
Which BB product do you have from EE?
For an EE Smart Hub, but not an EE Smart Router, try separating the wireless bands/SSIDs. On the Advanced > Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-". Then connect your devices to the 2.4 GHz SSID if they can't do 5GHz.
19-05-2022 01:26 PM
Thanks @NeilSalf
Normally if you connect a non EE router you have to enter your EE username and password, however there does seem to have been changes recently resulting in standard BT settings also working.
The BT HH6 also has combined 2.4 and 5Ghz Wi-Fi bands although it does not have the same modes as the later EE hub. If the BT hub works for you, the easiest solution would be to use it. But do keep the EE one in case of future issues.
