Instagram is blocked on EE broadband
Rky
Prodigious Contributor
I think someone reported this type of issue earlier but from yesterday I started facing this.
Instagram app is not loading any reels, feeds or msg when connected to broadband but when I switched to mobile data it worked
Speedtest report is 67mbps on my 67mbps plan
Sometimes Fire TV is also getting disconnected
Best Regards,
Raj
13 REPLIES 13
bobpullen
@Rky - do you have any parental controls settings enabled? Is it a Smart Hub or Smart Hub Plus that you have?
Rky
Smart Hub Plus, I checked and it is on strict mode, now I turned off, will provide feedback after few hours if turn off is helpful or not
Best Regards,
Raj
Rky
Looks like it worked, I’ll report back if this will happen again
Best Regards,
Raj
Rky
Problem was instagram was not working fine.
Solution is remove parental controls
Best Regards,
Raj
