Instagram is blocked on EE broadband
Rky
Prodigious Contributor
I think someone reported this type of issue earlier but from yesterday I started facing this.
Instagram app is not loading any reels, feeds or msg when connected to broadband but when I switched to mobile data it worked
Speedtest report is 67mbps on my 67mbps plan
Sometimes Fire TV is also getting disconnected
Best Regards,
Raj
Rky
Problem was instagram was not working fine.
Solution is remove parental controls
Best Regards,
Raj
13 REPLIES 13
Rky
Comment says couldn’t send try again and when I switched to mobile data comments are getting posted
Best Regards,
Raj
Rky
Instagram web is working but app is not loading reels and feeds when connected to EE broadband.
While on mobile data or other ISP broadband it works fine.
Best Regards,
Raj
Rky
Looks like many people already reported but EE has no clue
search link
Best Regards,
Raj
But not for Home BB!
Rky
Is there any solution?
Best Regards,
Raj
@Rky Are you asking forum members?
Rky
Yes I’m asking if any member know the solution.
By the way, I created a bridge in router and iPhone with custom DNS and issue is resolved but this is not something all EE broadband customer will be interested to do so I’m looking for solution in this thread
Best Regards,
Raj
Mustrum
@Rky  you are the only one with this issue, the link you provided showed issues with mobile broadband, not landline broadband.
Are there other sites you are not able to connect to?
What router and service do you have?
Changing DNS was this on the device or the router?
Have you tried a reset of each device/router?
Then you mention a Fire stick, it would be more helpful to see your roter stats or any other info you can provide.
Rky
This is EE smarthub blocking instagram, amazon delivery tracking maps etc not sure what other things are getting blocked.
Best Regards,
Raj
