IP address 0.0.0.0
togsdragracing
My Smart Hub Pro Hub Manager is showing a wireless device with an IP address of 0.0.0.0, lease expired and a Mac address which I can't knowingly tie to any device on my network. Router restart doesn't get rid of it.
Any thoughts? Apologies if this is an old chestnut, the Forum search engine leaves a bit to be desired.
What is the MAC addy?
togsdragracing
1a:61:b4:4c:9c:d5
@togsdragracing Just had my EE Smarthub+ update the FW to latest version and the only issue that i have had is my Asus RP-AX58 with total none data path connected to the router, RP off/on sorted out the 5Ghz side kind off, but not fully, the 2.4Ghz is on ip 0.0.0.0 as far as the EE Router is concerned, so going to have to power off the EE router and the Asus together but not until 7am tomorrow, so if know one else updates you i will tomorrow once i see what's going on.
This is the only device causing an issue, but not surprised as it was given a duplicate name of an Asus laptop months ago by the stupid app, and have not been able to correct that since, still got the stupid name....
@togsdragracing Apart form the IP i have at 0.0.0.0 and the 2.4Ghz is toast on the RP, all off my static Ip's have been turned off by the FW upgrade, so i may be a little bit longer sorting all this out now.
