I've purchased WiFi 7 from 3rd party, help needed.
Ripper1001
So I've upgraded to WiFi 7 from a 3rd party source but I'm having difficulty adding it to the app, has anyone else experienced this and is there a workaround? Also experiencing connectivity issues between the hub and the extender. I keep getting a flashing aqua light on the extender. Any help would be greatly appreciated.
1 ACCEPTED SOLUTION
Ewan15
Expert Contributor
Expert Contributor
I upgraded via the same route. The app will not show the Pro router as as far as EE are concerned you have not got one, however if you go to Manage -> Broadband -> Click on Router you will see this.
Interestingly the App does not allow you to screen shot the screen on Android unless you ask Google to do it for you!
As far as the extender goes.
  1. Connect it using an Ethernet Cable.
  2. Remove the Ethernet cable an let it stabilise (Solid Aqua Light)
  3. Switch off Extender and unplug
  4. Switch off Router and unplug (so memory clears)
  5. Reboot router and let it stabilise.
  6. Locate Extender and switch it on and wait for it to stabilise
Ewan15
Expert Contributor
Expert Contributor
Thank you that worked 👍🏻
My extender has started flashing aqua over the weekend. Any idea what that means?
Peter_W
Hey @Ripper1001.
Welcome to the Community 😊
A flashing aqua light on a Smart WiFi booster usually indicates that WPS has been activated, and it's waiting to connect to your Hub or other device.
Is it working otherwise?
If you're struggling, it's worth trying to initially pair over Ethernet and see if this works.
You can also find more details on our help article here:
Fix a Problem with Smart WiFi | Broadband Help | EE
Peter
