03-02-2025 07:20 PM - edited 03-02-2025 07:25 PM
Hello,
On the 9th of Jan I went live with FTTP - From what I can tell from the BT database I am the first and currently only person in the village on it. But I have already had problems that no one can seem to solve.
I do need to state that I am on 1.6Gbps and I have NO complaints about the speed - It's solid but I am getting constant intermittent disconnections that happen randomly during any downloads I do - from several protocols, ports and sources. This even happens when connected to a VPN. I don't use WIFI
I've worked for an ISP for 20 years off and on and when I last left FTTP was just coming out. However this is the first time I have ever had it. Some of my experience tells me things that need to be done. So the problem is that I will get a total loss of connection. ONT stays Green no matter how I connect to it. So here's what I have done to try and solve it.
I've connected my PC to the EE router. I've changed the 2.5Gbps Ethernet to USB-C adapter in case the old one was faulty. I've tried 3 Nvme drives with clean installs of Windows 10 and 11 on to rule out my Nvme being faulty. Each time I get a loss and I get  "WinError 10051" However the online fixes and adding stuff to the registry has not solved the problem. The connection comes back after a few mins without any intervention needed
I have an M1 mac Mini which also has the same make of Ethernet to USB-C adapter connected to a Thunderbolt port and I get exactly the same thing. On the MAC I am just told the address can not be resolved. The connection one again comes back after a few mins without any intervention needed. On both machines even connecting to the 1Gbps NIC using a fresh Ethernet cable gets the same results.
Thinking it could then be the EE supplied Router I decided I needed my own kit so I purchased the Asus RT-BE88U which is a decent bit of kit. This means I was connecting to the ONT via PPPoE - and I got the same result on both devices. So now I have ruled out the EE Router. I also connected each machine to the ONT directly via PPPoE and still I get the same result on each. I also replaced all the Cat7 cable.
So, as  I have ruled out everything inside the property - so it was time to call EE. An Engineer was sent out the next day - he found no faults and said my light was 18 (maybe -18)  which was spot on.
To further compound the issue I am in the last month of a leased Line which I have had for 5 years at 1Gbps speed. I've repeated all the download tests on both machines and NOT had a single problem - it HAS to be a line issue.
I am happy to call and log another fault, but the last Guide said they were lost what to do - Would I be unreasonable to ask to leave within 30 days as the problem has not been fixed?  If it's not a line issue it must be an ISP one? Could I use OTS to go elsewhere for 30 days and see if I get the same thing?
Thank you
04-02-2025 10:41 AM
Thank you kindly for all your help on this matter
I've been on with TS this morning who tell me the fix will be rolled out before the end of march and they say this will likely be the 1st of March onwards. However for me I am out, EE just let me out the contract and terminated my service without any penalties.
04-02-2025 11:46 AM
Thanks! You're welcome 🙂 ! Glad I could be of assistance. Sorry to see you go.
04-02-2025 02:25 PM - edited 04-02-2025 02:25 PM
My neighbour is having his whole front garden dug up to get the FTTP - He's also going with EE on 16Gbps I hope he is not disappointed.
