14-04-2026 10:27 PM - edited 14-04-2026 10:28 PM
I think that the EE App can do with some more features.
on 15-04-2026 12:22 PM
on 15-04-2026 06:22 PM
Many thanks @Peter_W - There's a feature that exists to export the logs of the router. Please would you also introduce a feature to export the list of devices to a CSV format? Cheers.
on 16-04-2026 09:19 AM
Morning @BennyB0Y
Thanks for sharing your suggestion, I have passed this onto the relevant team 🙂
Have a lovely day.
18-04-2026 03:58 PM - edited 18-04-2026 04:00 PM
Thank you @Leanne_T
Please would it be possible to add the feature where you can enter a fixed IP address outside the scope of the DHCP range? For example the default DHCP range is from 192.168.1.54 to 253. Entering an IP address like 192.168.1.10 raises a restriction message about only being allowed to enter an IP address within the scope. Maybe this could be a warning instead? I know that you could temporarily change the DHCP scope and then change it back, but that is not a full solution. Having a full feature like this would give customers that little more power over configuring their LAN. Thanks.
on 19-04-2026 09:44 AM
Hi @BennyB0Y
I've passed this feature request on for consideration. Thanks for sharing your observation on this.
Ali
on 22-04-2026 10:42 AM
@BennyB0Y wrote:I know that you could temporarily change the DHCP scope and then change it back, but that is not a full solution. Having a full feature like this would give customers that little more power over configuring their LAN. Thanks.
You could always configure the IP directly within the connecting device's network settings?
22-04-2026 02:56 PM - edited 22-04-2026 02:58 PM
@bobpullen wrote:You could always configure the IP directly within the connecting device's network settings?
Hi @bobpullen - I've done this already for a couple of devices which allow the IP address to be set manually, so thanks for this suggestion that I have used. However there are some devices (E.g. Wi-Fi speakers) where setting a fixed IP address can only be achieved through DHCP Reservation within the router's settings, and not on the device itself. I'm looking for that little extra flexibility in the network admin side of the EE app. Thanks again.
