How to connect EE digital voice to TP link AXE 75 router
Jamjul
Hi
I am changing my broadband from BT to EE (same company). I use my TP link AXE75 router as opposed to the BT hub. How do I connect the digital voice adapters to the TP link router to connect my home phone which is changing from analogue to digital?
9 REPLIES 9
@Jamjul : You can't! It can only be connected to the EE supplied router which must be the 1st router downstream of the BB supply. You may then connect a secondary router to handle device connections.
Which EE BB plan have you ordered including its speed?
Mustrum
@Jamjul   not sure what happened to your  original post, has it been moved or something?
When you change from the old voice package to Digital Voice the voice connection moves from the copper phone connection to a Digital one on the EE or BT Router.
Given the specs on your TP Link router I am guessing you have a copper line for the phone connection, but a digital line for your broadband. Unless you still have an Openreach modem connected to your copper line.
Ether way, the EE router needs to be the first connection on the line for Digital Voice. You could switch the WiFi off on the EE Router and connect all other devices to your own router.
HTH
Jamjul
Hi
Thank you both for helping me. I have managed to connect the EE router with my TP Link by turning off the WiFi on the EE hub. . It’s works very well  and saved me a lot of time connecting all my devices.
Peter_W
Hey there @Jamjul, I'm really glad to hear that you've managed to get this sorted out.
Thanks for taking the time to come back and update the thread too 😊
You take care,
Peter
How did you do this? I’m in a similar situation and want to use tp link router. Any help would be appreciated
I’m in a similar situation with a tp link router how do I do this please
@Jonbagg In your similar situation do you still require to maintain a landline telephone connection for voice? If so then you must use the EE supplied hub for connection with your Tp link on the back off it. Setup video is below, you just need to work out what connection you are trying to do.
Download for Archer AXE75 | TP-Link United Kingdom
Thanks for your reply.
Would I connect ee router to phone line turn off its wireless? How do I connect the ee hub to the tp link ?
I’m wanting to use tp link router for broadband and the ee hub just for the digital phone line
Thanks again
Sent from my iPhone
@Jonbagg Ethernet connect Lan of Tp to the Lan off the EE, if you have them sitting next to each other then yes EE wifi off would be best. Tp-Link guide will show you what to do.
EE Hub has to connect to the OR Master phone socket if that is your connection type, the TP is just not capable off doing so if the same version as posted above and that is what you are referring to ie axe 75 model from TP. This is the one you need to look at, ""What should I do if I cannot access the internet? - Using a DSL modem and a TP-Link router""
This is really what you need to be doing, search tp link axe75 ap mode configuration, and go that way.
