Help with fire stick setup with EE broadband-can’t get rid of cookies screen
GeraldineG
I am trying to set up my fire stick. I go thru all instructions, get to Join EE WiFi but in front of the instructions to do do I have a large Cookies screen which I cannot get rid of by using up and down arrows
9 REPLIES 9
Matt_124
Is it your Home Broadband you are trying to log on to or the public EE WIFI hotspots?
If it is your Home Broadband, this is not called "EE WIFI" but is usually "EE-" followed by a combination of letters and/or numbers (or if you have moved from BT and kept the same hub, the same details would still apply) as reflected on the back of your router. It does not ask you to approve cookies or anything of the sort.
EE WiFi hotspots
Leanne_T
Hi there @Steviet71
Thanks for posting 🙂
Do you have a WiFi hotspots query we can help you with?
Karlmmmm
Did you ever figure this out??
Leanne_T
Hi there @Karlmmmm
Do you have a cookies screen showing when connecting to WiFi? Do you have a home or mobile broadband device?
Thanks 🙂
Leanne
HM141
Hi, I have the same problem, did you get it sorted and if did go you tell me how please
Alex_H
Hi @HM141,
Welcome to the EE Community
Just to clarify, are you connecting your Firestick via EE Public WiFi or is this on your EE home broadband connection?
Is it when directed to the EE public WiFi login page you are being asked to accept cookies, or what page is it asking for cookies on?
Alex
It's my on home EE broadband, as soon as I put firestick on the big cookie page comes on and can't get rid of it, would you know how to fix it please
Rach_H
Hi @HM141,
Welcome to the Community!
I'm sorry to hear about the trouble you're having. Can you try turning off and restarting your router, to see if this helps?
Rach
