Guaranteed download speed not high enough to stop service dropping out.
jaketheplumber
Switched from BT to EE on 05/08, checked that my download speed what at the level guaranteed (44.91Mbps) and all seemed ok for a day or two. Service started dropping out after a few days, went through the test procedure on the EE site and was informed of a fault, engineer was booked to investigate. Started monitoring my download speed and it was only half of the guaranteed speed, sometimes as low as 18.8. Engineer arrived on 13/08 and said the only way the problem could be solved was by asking EE to raise the cap on the download speed. He did this via a phone call after he left and after I reset the hub all was ok again, download speed was back to 50 or more.Within 2 days it all went pear shaped again.I kept a check on how often the service dropped out and it happened at least 4 times a day from 15/09 - 25/09. During this time the speed was generally around what it should be but the service was still dropping, yesterday and today it has dropped out several times and the speed is back down to 27Mbps. Tried phoning yesterday and ended up on hold for what seemed like an eternity while constantly being told by EE how important my call was to them. Really don't know what to do next.
177 REPLIES 177
Mustrum
@jaketheplumber  it sounds like you have a fault on your line that is getting worse so DLM reduces your speeds. Whilst the reset fixed it temporarily, the underlying fault is still there.
It will no doubt need another Openreach to track down the issue.
Not sure why you did not speak to EE about this?
Maestro
Maestro
@jaketheplumber What router are you using for the service, and do you know if you are for sure on fttc, copper to the home?
jaketheplumber
I didn't speak to EE about it because I spent so long on hold yesterday I almost ran out of credit on my phone. When I hit the contact us button this morning  I got a message on screen saying 'We are currently experiencing problems, please try again later'
jaketheplumber
I haven't spoken to EE about it because I spent so long on hold yesterday that I nearly ran out of credit on m y mobile. When I hit the contact us button this morning I got a message saying 'We are currently experiencing problems, please try again later'
jaketheplumber
I'm using a Smart Hub Plus plugged into the master phone socket. There are no other connections involved, my pc is wireless.
jaketheplumber
I have no ethernet connected devices, just the Smart Hub Plus plugged into the master phone socket, the light on the hub flashes orange every time it cuts out.
I tried to do as you suggested re. router stats. I logged in to EE and can't find Advanced Settings anywhere.
Can't do a wired speedtest, there was no ethernet cable supplied just the hub and a filter which I didn't need.
@jaketheplumber  from the speeds you mention in your first post it appears you are on FTTC, but you do need to contact customer services, use the 0800 079 8586 it is free other than the connection charge if you are PAYG I believe.
In plumbing terms there is a system that reduces your speeds if there is noise or breaks on the line to help maintain service, as it was only reset and the fault not found last time Openreach came out your speeds have been reduced again. It needs a proper investigation,.
If the call back is not working try again later or persist with the 0800 number.
@jaketheplumber Have you had any problems or issue's on your previous router before you plugged in the EE Smarthub+ ?
