EE Smart Hub 7 Pro plus 3 Extenders
ngbc
Just swopped to Smart Hub 7 Pro from BT Disc System is utter rubbish, download speeds okay, but the system won’t mesh reliably, and keeps dropping out simply not fit for purpose, and the app is rubbish too, avoid
Maestro
Maestro
@ngbc See this link and the other direct help one also.
Solved: 3 x Extenders no longer reboot to aqua - The EE Community
Top Tips for pairing your WiFi Extenders to the Smart Hub 7 Pro - The EE Community
If you still have you BT system and the Hub is at least a BT Smarthub2 required for the DV side, you can use that as works on a EE System connection.
Maestro
Maestro
