10-01-2024 04:41 PM
Hey all -
After a complete nightmare getting the service up and running (they initially created the account as 900MB, had to cancel that account and are now trying to bill me for £1300), I finally have it running.
Imagine my surprise when the max speed is 900mb, exactly what I was paying for before - only now I pay more.
I called the EE team, they told me the SmartHub is rated for 1gb only - he even confirmed it in an email.
I'd appreciate any help on what I can do here.. very close to an Ofcom complaint.
Can I replace the SmartHub with a router of my choosing? Will this even work? If it does, I guess that's a partial solution however EE should float that bill - not me!
Any help appreciated,
Nick
10-01-2024 04:37 PM
Hey - I just had the new 1.6gb installed. They told me their SmartHub is rated for 1gb only. (1gb ports..)
Does this mean I can buy a router myself and replace the SmartHub? There won't be any issue doing this, the service isn't tied to EE router?
Any help appreciated..
10-01-2024 04:39 PM
I have the new 1.6gb service - being told the SmartHub ports are rated for 1GB only.. do I need to buy a new router does anyone know? Why do I have to float this cost when EE promised 1.6gb? This is dodgy territory and bordering on a scam as I'm not getting what I was promised.
10-01-2024 04:43 PM
@Zilos correct you can use your own router.
The one proviso, that you don't have EE's Digital Voice.
10-01-2024 04:46 PM
Thank you @Mustrum - that's really helpful.
One more question if that's OK.. Do I need to buy a whole new router, can I just buy a switch? The routers with 2.5gb ports seem quite expensive!
10-01-2024 04:48 PM
The connection is rated for 1.6gb. The ethernet ports in the standard hub are 1gb. You can saturate the WiFi to 1.6gb . If you want to go faster you need to use a 3rd party router. You can replace it of any router of your choosing. I chose the Asus gt-axe16000, which can handle multi-gigabit connections. But you can pick whatever you want. Just plug it straight into the ONT.
10-01-2024 04:50 PM - edited 10-01-2024 04:58 PM
A switch won't help. It's still limited by the 1 Gig LAN ports on the SH+.
10-01-2024 04:50 PM
@Zilos Not sure a switch will do you much good, the connection needs to authenticate via PPOE, although the Username is just the generic BT one.
10-01-2024 04:52 PM
Appreciate that @miggle - thank you for the reply.
Feels weird I have to supply my own router and pay out of pocket.. does EE or BT not offer any 2.5gb port routers?
10-01-2024 04:55 PM
Yep, there’s only one 2.5Gbps port which you have to use to plug the ONT into the rest are only 1Gbps.
To really take advantage of the 1.6Gbps connection you need a WiFi 6E or 7 and/or or a router with multiple 2.5Gbps ports, your devices will need to be compatible with the router standards too.
Before my connection started to play up I was getting 1.3Gbps over WiFi using the EE router which is the best I’ve seen on the various routers I’ve tested but I was in the same room and next to the router.
Technically their WiFi 6 device is rated up to 1.6Gbps but in reality that’s unlikely to be achieved so it’s not mis-selling.
EE have said they want to be the first operator to launch a WiFi 7 device
