Full Fibre
Martinperyer
How close does my router need to be to the new internal box that Openreach are fitting next week. Also, will the connection be with an Ethernet cable.
pip11
Scholarly Contributor
The connection will be via ethernet cable. The hub can be up to 100 mts away using CAT 5e (or above) cable.
Thanks pip11 - this will help me position the new box in a much more suitable location
