Full Fiber Zero Upload
Poepox
This is a recurring intermittent issue I've been having with my full fibre broadband for the past month. I've contacted EE support twice, and they told me it's an issue with my wifi despite telling them multiple times it happens regardless of using wifi or Ethernet. Here is what a basic speed rest gives me.
 And here is a basic tracert:
 This were both done via an ethernet connection to my PC. The issue began the day after a severe thunderstorm and has basically rendered my broadband connection useless.
When I contact support they just keep telling me their diagnostic tools don't detect any errors, but clearly there is something wrong. It's quite frustrating to be paying £80 a month for a connection I basically can't use. I will try to contact support again in the morning but I'm currently at my wits end and seeking help resolving this issue or if someone could shed some light on a potential fix.
16 REPLIES 16
Poepox
Update: restarted ONT and the router as instructed for 10 minutes. Afterwards no internet at all, so phoned EE support again and they detected a fault this time.
They will be sending out a new router, and hopefully that fixes the issue. Fingers crossed...
I'll update again if it works or not.
Community Hero
Community Hero
@Poepox Not sure if you have or not been aware that the EE Smart Hub 6+ range off hubs has been going through a FW update from May onwards, if not can you say that please!
The  fact longer time off is not that significant, it just allows the EE Hub to get fully decade power wise so when it get's powered again it's going from zero upwards, there may or may not be that much wrong with it and would have been good if you had indicated what happened when it all rebooted, ie got to full Aqua state looked good but just would not play ball with anything, trying not to get you waiting day's then the new Hub throws it's hands up also.....
Dig your old Tp-Link out and get it on the connection at least prove your Fibre and the ONT are up and working.
Not sure how long you have had that EE Hub, a while back there was a bad batch off PSU units, NOTHING at all wrong with the EE Hub's the fault showed in a very specific and diagnosed way, it's one thing to keep in mind, not sure if it was tied to a particular batch etc but the easy is USE the same hub and Swap out the PSU with the new one, you seem to have a good handle on what you are doing so would spot the fault easily....
EE Hub firmware versions - The EE Community
They actually did send out a new PSU for this unit back in March so in swapped to the one I sent. Also the internet is still dead even though the router displays aqua/turquoise state, as I didn't rush any step of the proccess. Left in 20 mins before I contacted support.
I can try the TP link one tonight.
Most errors I get while trying to do anything are DNS errors, wether browsing, games or anything else.
Community Hero
Community Hero
@Poepox Then what about the Update to the FW is that done on the unit, the EE Hub has been highly unstable from the 25/05 this year! Tp is the way to go, that will prove the Fibre/ONT stability.
Firmware version: r4.26.3
Deployment date: From June 2026
Hub Type: SH30A, SH31B, SH32B
Release notes
  • Fix - Intermittent 2.4GHz connectivity
Firmware version: r4.26.1
Deployment date: From April 2026
Release notes
  • Platform updates & security patches
  • Improved WiFi stability/performance
  • New - Digital Voice Contacts backup/export
  • New - IPv6 DNS
  • New - EE WiFi-Auto
  • Fix - Microsoft Teams/UDP issues in some situations
  • Fix - Pixelation/IPC6023 errors in some situations when viewing subscription EETV channels
  • Fix - Ethernet/wired devices taking a long time to establish connection
So, got the TP-Link router up and running, its an old 3/4g router (Archer MR200) but it does have a WAN port.
Had to convert it over to WAN mode but got it to work.
Download is just low due to the ports of this old router being capped to 100mbps, but...
It works. Everything is smoothe, no issues, latency is good for the most part so it does indeed seem the router is the cause, as the ONT and connection seem perfectly fine now. Just incase ill let some tests run for abit just to make sure, but otherwise seems peachy.
Community Hero
Community Hero
@Poepox Real good start, when you get the replacement from EE just be sure it does it's latest FW update, reboots and works as you expect it to be.... The interim FW that was causing all the issues is just not due to be completed until End June 2026.
The TBB speedtest suggested by @JimM11 will not splatter your public IP on this public site & therefore all over the Net.
