Frequent disconnects
piggygoesoink
I have been experiencing frequent disconnects on my broadband line for several months now.
I have had two engineers visit and both have assured me that the line is fine.
I have called customer support numerous times and they have detected a fault once which was apparently resolved by open reach. However my line drops multiple times a day, but then sometimes is fine for a while, but I am constantly experiencing issues.
Any help would be appreciated.
8 REPLIES 8
The issue is broadband dropping as a whole. Ethernet connected devices also drop. Logging into the router shows the broadband connection had dropped. The lights usually change to flashing orange then eventually goes back to green once reconnected.
1.
Product code:Smart Hub 2
Serial number:+EEH002+2105005307
Firmware version:v0.05.01.09191-EE
Firmware updated:Thu Jan 5 01:06:42 2023
Board version:R01
GUI version:1.2 06_07_2022
DSL uptime:-
Data rate:-
Maximum data rate:24.529 Mbps / 81.679 Mbps
Noise margin:0.0 / 12.1
Line attenuation:0.0 / 35.9
Signal attenuation:0.0 / 35.9
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:-
Broadband username:
2.4 GHz wireless network name:
2.4 GHz wireless channel:Smart (Channel6)
5 GHz wireless network name:
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:
Software variant:-
Boot loader:0.1.7-EE (Fri Sep 20 18:43:31 2019)
2.
3.
Telephone number on EXCHANGE KINGSTON is served by Cabinet 11
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean) piggygoesoink_26-1674079869689.gif
8077.6201972.9AvailableAvailable--
8075.9201968.9AvailableAvailable--
295.2213.646.622.9189.5AvailableAvailable--
249.2183.732.716.4168.3AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33050--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 18--16 to 19.5Available--
Up to 18Up to 1.516 to 19.5Available--
Up to 7.5--6.5 to 8Available--
2----Available--
2----Available--
SOADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) WBC SOADSL Availability Date Left in JumperWBC SOADSL 2+SOADSL MaxSOADSL Fixed Rate
Up to 7.5--16 to 19.5Available--
Up to 2--6.5 to 8Available--
Observed Speeds G.FASTMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
185.45
37.01
2023-01-17
Other Offerings Availability DateVDSL MulticastADSL MulticastG.fast Multicast
Available
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
U
N
N
05-01-2023
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
N
Why is there no "Data rate" showing in the router stats?
Ah I copied this when broadband was disconnected. Here it is now:
Board version:R01
DSL uptime:0 days,09 Hours47 Mins15 Secs
Data rate:29.479 Mbps / 159.133 Mbps
Maximum data rate:37.753 Mbps / 189.112 Mbps
Noise margin:17.8 / 15.9
Line attenuation:0.0 / 33.0
Signal attenuation:0.0 / 33.0
VLAN id:101
Data sent / received:160.5 MB Uploaded / 18.5 GB Downloaded
Broadband username:
Firewall:On
MAC address:
Software variant:-
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
piggygoesoink
Hi
I have a Master Socket 5C,
When I remove the face plate and connect the phone line from the router into the socket I cannot get a broadband connection at all.
There are no phone line extensions. I don't see any wires connected to the back of the faceplate.
I don't have a telephone to test the line, however, I have had at least 2 engineers come and test the line and both have assured me the line is quiet with no noise.
This is the latest router stats. As you can see I have a short uptime due to the continual disconnections.
Product code:Smart Router
Board version:R01
DSL uptime:1 days,08 Hours28 Mins23 Secs
Data rate:29.488 Mbps / 159.051 Mbps
Maximum data rate:35.563 Mbps / 176.692 Mbps
Noise margin:18.1 / 15.3
Line attenuation:0.0 / 32.3
Signal attenuation:0.0 / 32.3
VLAN id:101
Data sent / received:3.6 GB Uploaded / 18.8 GB Downloaded
Broadband username:
2.4 GHz wireless channel:Smart (Channel1)
Wireless security:WPA2 (Recommended)
Firewall:On
MAC address:
Software variant:-
@piggygoesoink    did you use a dangly filter when you tried the test socket?
You do have a dingly micro-filter on it?
Follow Linebox NTE5C User instructions to get to the test socket.
The QLT is the most important test to help diagnose faults such as yours. Noise on the line is the most common cause of BB failing or going slow.
