No broadband connection, lost , it has gone off 3 times in 1 week Dalkeith Eh2
Gillian2105
@Gillian2105 : Welcome to EE's Home Broadband Forum.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
