DSL Reset.
mk5912
My home internet disconnects almost daily at varying time (only started happening approximately 1 week ago, 15/04/2025), I have checked the logs on the router and it states the DSL connection was lost and anywhere from 1 to 5 minutes later it reconnects, is this an issue with the hub or with the external cables?
I have had EE WiFi for about 2 years now with no issues like this.
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Mustrum
@mk5912   not a lot to go on there, but why not follow the advice on the Help pages.
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
Our lines are currently closed.
Opening hours:
Support for Deaf and hard of hearing customers
Opening hours:
