Forgotten wifi password
Nix5
I changed my wifi password a while back and have now forgotten it. How do I retrieve this?
7 REPLIES 7
Nix5
@Nix5   You factory reset the router if you can not remember it.
No, you don't need to factory reset it. Which router is it? You can always login to routers & see the current pwd in clear.
It’s a broadband (fibre) router
Yes, but which 1? If it's an EE Smart Hub or Router just follow Changing Your WiFi Password on a Smart Hub & you'll see your WiFi pwd in clear.
How does one log into the router?
@Anubis :Which router?
