Broadband
Addylaing1
Hi there, I currently have virgin media broadband and I’ve just bought an ee broadband bundle will there be any issues with installing it if i already have a fibre line out in?
6 REPLIES 6
There should be no issues installing EE Fibre BB. They are completely diff lines & systems.
Have you cancelled your VM contract? You need to do that yourself. EE won't do it for you as it does for most other ISPs.
No so I’m getting the ee broadband for the upstairs of the house as the virgin media just isn’t doing it for us up there so was just hoping to see if that could actually work thanks
Christopher_G
Hi@Addylaing1
Is it a Mobile Data (4G/5G) router that you've bought or fixed line?
pip11
Scholarly Contributor
@Addylaing1   @Christopher_G  Expensive way of resolving the problem. But if you've ordered fixed line broadband or mobile it would make no difference. VM is independant and delivered differently to EE. You won't have any issues.
It’s a fixed line
pip11
You'll be OK, it won't effect you VM connection.
