06-10-2022 01:36 AM
Hi!
I recently posted an issue with smartwifi discs: couldn’t get Wi-Fi in our bedroom!
I’ve now reset and moved all the discs and have used the Ethernet cable to wire in to an Ethernet socket and it now works brilliantly!
However, the Ethernet cable I’m using that came with the discs to set up is too short but does the job. I need a longer one (about 1 metre in length). Just googled Ethernet cables and they’re all so different!
What should I be searching for?
06-10-2022 03:11 AM
Ethernet (aka RJ-45) CAT 5e or above. The plug at either end is RJ-45 Male.
06-10-2022 03:11 AM
