27-02-2024 10:40 PM - edited 27-02-2024 10:52 PM
Moved to EE in January. Three weeks ago hub started flashing orange and landline stopped working. Told it was due to an open order, then told there was a fault after an engineer called no fault found but still no service. Now told there is a external network fault. Said I was fed up with lack of information and no service so would be leaving only to be told that I would lose access to my btinternet emails. So forced again to stay only to find out that it was a lie, you just get moved to a web based email. I need a broadband service and a landline and EE doesn’t appear to be able to fix this problem but expects me to stay and keep paying for nothing. Even the EE advisors and I have spoken to many have said to move to another provider.
28-02-2024 09:31 AM - edited 28-02-2024 09:31 AM
@Rockett1 unless you have access to another suppliers lines there is little point in moving as your line and fault will still be there. Plus you will be waiting 10 days before a new supplier can get you connected - and a bit longer to find the fault on the line.
Fortunatley line faults are not that common, but can be a pain to find and fix, keep on top of the fault team I am sure they will get it sorted as sonn as they can. Don't wait for them for info, make sure you keep in touch.
on 29-02-2024 10:49 AM
Thanks for your reply. I have been ringing them almost every day and they just keep saying sorry. I reported the fault on 13th feb and still have no service today the 29th. I need the broadband and a landline and still they are charging me for supplying nothing.
34 years with BT and now this. I give up
