No audio when receiving or making calls
andydaws
Valued Contributor
Valued Contributor
I keep getting problems making and receiving calls with no audio
If i restart my EE Pro hub it then comes back for a while but not very good think this is the 3rd time I have noticed it
I will attempt to see if next time it is one way audio etc as might indicate something like possible a SIP ALG problem (We have no control or means of seeing these settings on the EE Pro Hub or any uPNP opened ports seems poor security) issue as the control (TCP) channel obviously working as it calls but no UDP audio
Working again now but if you have known issues you are working on it would be appreciated
0 REPLIES 0
