Flint 2 advice
Shannint
Unable to connect Flint 2 directly to ONT, so using smart plus in between. Followed advice in third party routers, any advice on how to connect  Flint 2 directly.
Why can't you connect Flint 2 directly to ONT? It has a 2.5 Gig WAN port.
In Using & Configuring a Third Party Router you'll find everything you need to set up your router incl. the BB PPPoE creds. which are now the same as BT's.
Maestro
Maestro
@Shannint And only this part!
Full FibreConnection type: Point-to-Point Protocol over ethernet (PPPoE)
Broadband username or login name:[email protected]
Broadband password:BT (or leave blank)
Authentication:CHAP
DNS:Auto or Obtain from ISP (we'll automatically provide these when you connect)
