15-06-2026 11:18 AM - edited 19-06-2026 10:06 AM
Following a recent firmware update, some Smart Hub Plus customers may find that certain WiFi devices or WiFi extenders have trouble connecting.
Our engineers have identified the cause of the problem and are now rolling out a fix to affected Smart Hubs.
If your wireless devices aren't connecting and you have a Smart Hub Plus, setting the 2.4 GHz channel can resolve the issue.
If you have devices that will not connect, please try reconnecting using Compatible WiFi.
We are working as fast as possible to fix this issue, but in the meantime, some of our customers have found the following steps help:
You can find all the latest updates on this issue in Fix problems connecting devices to your Smart Hub Plus or Smart Hub 3's WiFi | Broadband Help | EE
23-07-2026 07:45 AM - edited 23-07-2026 07:49 AM
@TinaA1 You do have the 14 day cool down period window to do so, keep an eye on the timescale.
Without knowing the details to what you have not much the Forum can do help wise. Try the HELP to 66033 and that text will initiate EE to run a check against your connection and Equipment installed, plus any devices that are connected. Can be anything from the Hub install, the position off your Extenders etc, the strange part is when installed it was all good then 5 days later not stable/working, look at the light status on the Hub/Extenders they will give you the idea what is going on, Aqua colour on everything is what you need. Since you mention extenders that would mean you have more than one? The EE range below to what the have currently device wise.
23-07-2026 03:00 PM
have another engineer coming out on saturday
i have the smart hub 7 pro, I initially had one extender which disconnected, everyone i paired then moved it, kept disconnecting. After a call to helpdesk, they sent another 2, with an engineer visit.
engineer says all 3 are faulty and I should only need the smart hub, he said I was set up with WiFi compatible, he got everything working, TV apps all working Apple iPhones connecting, 30 mins later, apps stop working, some phones are connecting, laptop connected, but teams app not working.
a new smart hub pro 7 is being delivered with another engineer visit.
everything was working fine with one extender upstairs until Monday…
i rebooted hub last night, still nothing. I’m losing the will to live…
shouldn’t be this hard
23-07-2026 03:02 PM
That should say every time I paired the extender and moved it, it disconnected.
i had to pair with Ethernet cable
currently only have smart hub connected but it’s not fully functioning
