Fix port forwarding
ivannetta
For some of those that might struggle with opening ports and then realising they dont even work i have sigma fix for this ♥️♥️
go to ur firewall settings on admin panel, click configuration and turn off upnp and ur done 🥺
Dont call ee support asking for help with port forwarding as i waited 40 minutes to get transfered 3 times and get told they dont know 😢
Maestro
Maestro
@ivannetta With what relevance to the specific and yes EE may not be able to answer regarding port forwarding. EE help guidance is there for that reason.
Port Forwarding: Access to your home network | Broadband Help | EE
Maestro
Maestro
Debbie_G
Hi @ivannetta.
Welcome to the community.
Thanks for sharing what worked for you. The link @JimM11 posted above includes helpful step‑by‑step instructions for setting up port forwarding on EE hubs.
Debbie
bobpullen
Not sure why this would be required unless UPnP had automatically created a port forwarding rule that clashed with one you were trying to setup.
I have UPnP enabled and have no problem with port forwarding 🤔
