Connectivity hub won’t connect to main hub
Helen311
My smart hybrid connect won’t pair with my main hub, they both turn aqua and the wifi works for two seconds then it starts flashing and turns off. What do I do ? Now it’s flashing green on the big one and red on the hybrid connect. Iv tried restarting it and it does the same thing several times.
