Firmware update
andyrew2008
Had update tonight on my smart hub.
Any changelogs? Still no ipv6
Version v0.08.02.12273-EE
bobpullen
Star Contributor
Star Contributor
WAN side IPv6 is a network side change, not a hub side change AFAIK. Assuming that to be the case, you can't expect IPv6 via hub software update, it's dependent on it being enabled out on the network.
i.e. the hub is ready; just needs the network.
Edit: can't help you with the changelog... sorry.
You won't get any changelog from EE.
IPv6 would require a change to the EE BB network, not the router, & that hasn't changed.
MMMussel
New to the forum and trying to apply for Cyber Essentials Cert.
Can anyone please tell me HOW do I show evidence that my smart hub is being updated?
Thanks!  Mary
Hi.
If you look in the logs, it tells you if it is being updated
