Fibre internal connection box
edbostan
Openreach converted me to fibre running the fibre cable and connections. I have noticed that the faceplate on the internal box with the flashing green lights swivels and appears not to be fixed tight on the backing plate. My sister-in-law also had Openreach install to install her fibre connection and her faceplate also swivels on the backing plate. Can I concur that it is meant to be loose?
No, mine isn't! Report it to CS.
