19-06-2026 04:01 PM - edited 19-06-2026 04:19 PM
We had the wi-fi dropout problem which looks to be fixed by the latest firmware, r4.26.3. However, we still have one problem which wasn't there prior to the r4.16.1 update and is not fixed by r4.26.3. This is that one laptop, an HP, reconnects to the wi-fi every 6 seconds. The Hub is an SH31B
This issue is not obvious unless you look at the log, or do something like streaming or a video call and notice that it is freezing or stuttering.
Please, everyone, go to the Hub web page at 192.168.1.254, go to Advanced Settings, Technical Log / Event log tab and scan the log for any device (MAC address) connecting multiple times. You will probably need to hit the Next page button several times, but with us, the same MAC address connecting every 6 seconds becomes very obvious after only a couple of next page-s.
If you ARE getting this problem, can you please post here and include info such as Main vs Comp wifi, what GHz it's connecting at, and anything else you think relevant.
09-07-2026 05:33 PM - edited 09-07-2026 05:58 PM
@Cliff_G Agreed, Powerline works then just keep it connected that way!
Just checked and did the same steps with my old wifi4 Asus laptop from 2013, exact same results as posted earlier by the looks off it.
02-08-2026 01:28 PM
Interestingly getting the same issue on my Windows 11 PC since around May when the hub firmware was updated to 4.28 (now on 4.29). Sometimes connects to the extender immediately, other times connects to the more distant hub, then will randomly disconnect when trying to browse a different site. To maintain the 900MB speed, I've forced the PC to use the 5Ghz band, as it would try 2.4Ghz.
Similar to your log, my log is showing frequent issues with the WLAN-Autoconfig MsmSecurity tasks frequently connecting and disconnecting with encryption type AES-GCMP-256. However it becomes stable once it tries AES-CCMP encryption and I have no further MsmSecurity entries after this happens.
Not sure whether this is is a Windows issue. driver issue or EE Hub / Extender issue, will have to do some more experimenting to nail it down.
02-08-2026 01:44 PM - edited 02-08-2026 02:01 PM
@jbareham Completely different EE Hub if your FW that you are reporting is correct. Check your windows 11 build. 26200.8973
02-08-2026 02:15 PM
My Windows 11 Build is 26200.8973, have Hub 7 Pro and Wireless extender both on 4.29. Have checked my wifi card capability with 'netsh wlan show drivers' and reports back the following (it is on the latest available driver)
WPA3-Personal CCMP
WPA3-Enterprise CCMP
WPA3-Enterprise TKIP
WPA3-Enterprise 192 Bits GCMP-256
The hub is set to WPA3-Personal Transitional, so not sure at the moment why the card is trying to negotiate a connection using GCMP instead of CCMP.
02-08-2026 02:43 PM - edited 02-08-2026 02:56 PM
@jbareham You can either go up to full WPA3 mode and see what happens with it and that fully depends on what else you have for wifi 7 ONLY devices, or drop back which i think you may have done to WPA2-Personal connection on the EE Hub, possible it is your windows machine but trust not the Transitional option. Future windows correction is around the corner patch tuesday coming up shortly, but did see the WLAN struggle with the previous patch and i am set FULLY WPA2-Personal although wifi6 on the Hub as AX is it's baby and the laptop is only wifi5 but 160Mhz capable which it holds fine. Latest download calmed the writes down in the log file.... Have xxx out to get through the filters without issue and mod's changing....
Information 22/07/2026 17:00:52 WLAN-AutoConfig 11004 MsmSecurity Information 22/07/2026 17:00:53 WLAN-AutoConfig 11010 MsmSecurity Information 22/07/2026 17:00:53 WLAN-AutoConfig 11005 MsmSecurity
Many such entries but not 100% same as you may be seeing for your specific connection to your Extender or Hub.
Wireless security stopped.
Network Adapter: Intel(R) Wireless-AC 9560 160MHz
Interface GUID: {d348ab4c-xxxx-4660-xxxx-c16fd7987717}
Local MAC Address: F4:xx:xx:xx:xx:xx
Network SSID: SKY6xxxxxx
BSS Type: Infrastructure
Security Hint: The operation was successful.
And what it was struggling with securities wise.
Authentication: WPA2-Personal
Encryption: AES-GCMP-128
FIPS Mode: Disabled
802.1x Enabled: No
02-08-2026 02:57 PM
@JimM11 Can only select WPA-3 Personal or WPA-3 Personal Transitional on the Hub 7 Pro, one option may be to go to WPA3 Personal mode, and enable Compatible Wifi which allows a separate WPA2 Wifi for the WPA3 incompatible devices. The PC is 801.11ax Wifi 6E compatible, but some further experimentation and waiting for patch Tuesday might eventually resolve this.
02-08-2026 03:00 PM
@jbareham How it looks now since the update.
Information 02/08/2026 08:20:34 WLAN-AutoConfig 8001 AcmConnection
Information 02/08/2026 08:20:34 WLAN-AutoConfig 11005 MsmSecurity
Information 02/08/2026 08:20:33 WLAN-AutoConfig 11010 MsmSecurity
Information 02/08/2026 08:20:33 WLAN-AutoConfig 11001 MsmAssociation
Information 02/08/2026 08:20:33 WLAN-AutoConfig 11000 MsmAssociation
Information 02/08/2026 08:20:32 WLAN-AutoConfig 8000 AcmConnection
Information 01/08/2026 23:44:39 WLAN-AutoConfig 11004 MsmSecurity
Information 01/08/2026 21:00:32 WLAN-AutoConfig 8001 AcmConnection
Information 01/08/2026 21:00:32 WLAN-AutoConfig 11005 MsmSecurity
Information 01/08/2026 21:00:32 WLAN-AutoConfig 11010 MsmSecurity
Information 01/08/2026 21:00:32 WLAN-AutoConfig 11001 MsmAssociation
Information 01/08/2026 21:00:32 WLAN-AutoConfig 11000 MsmAssociation
Information 01/08/2026 21:00:32 WLAN-AutoConfig 8000 AcmConnection
Information 01/08/2026 20:39:03 WLAN-AutoConfig 11004 MsmSecurity
Information 01/08/2026 08:53:00 WLAN-AutoConfig 8001 AcmConnection
Information 01/08/2026 08:52:59 WLAN-AutoConfig 11005 MsmSecurity
Information 01/08/2026 08:52:59 WLAN-AutoConfig 11010 MsmSecurity
Information 01/08/2026 08:52:59 WLAN-AutoConfig 11001 MsmAssociation
Information 01/08/2026 08:52:58 WLAN-AutoConfig 11000 MsmAssociation
Information 01/08/2026 08:52:58 WLAN-AutoConfig 8000 AcmConnection
02-08-2026 03:00 PM
@jbareham interesting. How did you get the machine to use AES-CCMP? And what flavour of W11 is yours, Home, Pro, Enterprise, etc.? I'd like to see if this makes a difference on a W10 Home version. Claude suggests the AES type is simply a function of the WPA type, and is only GCMP on WPA.Enterprise. All else is CCMP.
02-08-2026 03:02 PM - edited 02-08-2026 03:17 PM
@jbareham Just be careful when you go Up on the Main, all the OLD devices that are NOT WPA3 fully will not connect at all.
Will have a look on my 6e Laptop to see what is going on, the desktop is MOSTLY wired but occasionally i double up on both for max throughput when i need the transfer speed.
NO 6e 6Ghz on my Asus Router that's for sure.
Edit:- Have powered it up, one version back windows 11 still, disconnected the Lan connection and running on wifi, fired up fine minimal entries GCMP-128 connected just now but will give it a check in a few hours time. Have steered it towards the same Asus AP as the other laptop, hopefully it does not jump to the Main Router.
02-08-2026 03:16 PM
@JimM11 Windows 11 Home. The PC eventually after a number of starts and stops of the WLAN service tries the CCMP rather than the GCMP, but no way to configure. Sometimes it connects immediately. The driver indicates that it should use CCMP for WPA3 Personal, but tries GCMP instead, can't find out why yet. The Compatible Wifi option on the hub covers those items that can't connect via WPA3. The Smart Hub 7 Pro does have 6Ghz connection, but I found I get full 900MB speed on 5Ghz, so use that. Logs are below, definitely looks something to do with attempting to connect with GCMP instead of CCMP.
Log Name: Microsoft-Windows-WLAN-AutoConfig/Operational
Source: Microsoft-Windows-WLAN-AutoConfig
Date: 02/08/2026 13:00:20
Event ID: 8001
Task Category: AcmConnection
Level: Information
Keywords: (1024),(512)
User: SYSTEM
Computer: xxxxxxxx
Description:
WLAN AutoConfig service has successfully connected to a wireless network.
Network Adapter: MediaTek Wi-Fi 6E MT7922 (RZ616) 160MHz Wireless LAN Card
Connection Mode: Automatic connection with a profile
Profile Name: xxxxxxxx
SSID: xxxxxxxxx
PHY Type: 802.11ax
Authentication: WPA3-Personal
Encryption: AES-CCMP
802.1x Enabled: No
Hidden: false
Date: 02/08/2026 12:59:56
Event ID: 11004
Task Category: MsmSecurity
Level: Information
User: SYSTEM
Computer: xxxxxxxx
Description:
Local MAC Address: xxxxxxxx
Network SSID: xxxxxxxx
Date: 02/08/2026 12:59:53
Event ID: 11010
Level: Information
User: SYSTEM
Computer: xxxxxxxx
Description:
Wireless security started.
Local MAC Address: xxxxxxxxx
Encryption: AES-GCMP-256
FIPS Mode: Disabled
802.1x Enabled: No
