Ethernet connection from home hub to wife smart plus booster
mike964312
After some advice, we have a smart hub plus (WiFi 6) in our house and 4 smart WiFi plus (booster/extenders) dotted around our house. We have an issue in that one of the smart WiFi plus boosters gives out a really intermittent WiFi signal on both frequencies as I think it's right on the edge of connection to our main hub. Typical this booster is an important one as it connects to our home solar panel system, car charger and a few other important WiFi devices. My question is I have the ability with a pre-existing cat 6 ethernet cable to plug the dodgy smart WiFi plus booster into our main home hub, will this I anyway help boost the WiFi signal from this smart WiFi plus booster??
Thanks in advance, Mike.
Mustrum
@mike964312  yes that should help improve things.
Mustrum
Community Hero
Community Hero
@mike964312 Not sure what the Mesh limit amount count is on for Smart wireless devices, but you may just be trying to push the boundaries as to what can be done.
