01-06-2022 05:03 PM
Hi all
I've signed up for EE fibre max. I'm already on FTTC ADSL (getting 76Mbps) with Plusnet. Have a landline but hardly ever use it.
They've scheduled an engineer visit in a week's time, but I'm not convinced one is necessary. I've already received the new hub/router. What might the engineer actually have to do?
02-06-2022 12:01 AM
Ah, that's more like it. There's no consumer FTTP there but there is G.Fast. So that's what you'll be getting.
Currently EE offer free set-up on all Fibre. I don't see you should be paying £50 for installation. Yours is a straightforward move from VDSL to G.Fast by the book. You don't even need the OR modem.
01-06-2022 05:21 PM
Switch you from an FTTC VDSL2 (it's not ADSL) connection to G.Fast, at the cab. It probably won't need a home visit.
01-06-2022 05:38 PM
Is it worth me phoning them? I would like to avoid the £50 engineer visit charge, I've read elsewhere that they might be needed to change the master socket maybe.
01-06-2022 05:51 PM
There is no reason to change master socket if VDSL2 has been running OK from it. Anyway an engineer has been booked to do the changeover.
01-06-2022 06:06 PM
@Phenoplastic have they quoted you £50 for an engineer visit or are you assuming it will apply?
Fixed Landline Broadband installs are Free Setup, so if you have been told its £50 I would be giving them a call as soon as I can.
01-06-2022 06:37 PM
EE Fibre Max is FTTP - you are currently on FTTC.
An engineer visit will be necessary to run the fibre from the cabinet to your home and potentially route the fibre to a different place in the house - specifically one which has twin mains power outlets for the termination unit and router.
01-06-2022 07:01 PM
@IT-4BusyPeople : EE Fibre Max is usually FTTC G.Fast but EE will provide an FTTP variant based on the G.Fast profiles.
01-06-2022 07:34 PM - edited 01-06-2022 07:37 PM
@XRaySpeX Thanks, I just assumed from a look at the website Fibre Max (FTTC G.fast) had been dropped and only Full Fibre Max (FTTP) is now being sold and given the pricing...
This article clearly states what the engineers' visit is for with a G.fast deployment.
Just look at the sections titled "How are Fibre Max 100 and Fibre Max 300 plans installed and set-up?" and "What will the engineer do?"
01-06-2022 07:57 PM
@IT-4BusyPeople : G.Fast Fibre Max will still be sold in areas that don't have FTTP but do have G.Fast.
All in all a good description of FTTC G.Fast but nowhere near for FTTP.
01-06-2022 08:00 PM
@Phenoplastic : To check which Fibre Max you can get there, what does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
