Re: Smarthub frequent reboots
DJSHAMONIX
They know its there fault , since 24th may every 2hours it goes down , dont let them try blame router or you , the only fault is joining ee , Hub has activated against the device management system , Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT , these 2 log events says it all , ee no ipv6 as there behind , there system cant handle it so when router gets request from any ipv6 device , web request ect it fails , the only way is to claim loss of service and join a service that works , roll on starlink if only it was more affordable.
17 REPLIES 17
DJSHAMONIX
DJSHAMONIX
DJSHAMONIX
Pretty much covers all uk , ee you have a problem , your going to file we have to many claims please let us file bankruptcy along with a few more , I see future EITHER SORT OR you finished !
DJSHAMONIX
I see there is no response from EE , CALLED OUT cant handle when truth appears , just sort it instead of fob offs !
DJSHAMONIX
it may seem I'm a disgruntled EE Customer ! , but you know its true , Why ? dont you just admit your service is below par ? , im going to make sure that people claim for your abuse of the system , fix it or lose !
@DJSHAMONIX :
  1. This is not CS but a user discussion forum. By using it you are not talking to EE but to other users, like yourself, who are here to offer aid. I don't have any service below par nor do I abuse any system!
  2. You're barking up the wrong tree with IPv6. The EE Home BB network doesn't use it.
  3. Those EE Outage maps & stats relate predominately to the mobile network.
    BB issues are rarely localised but specific to your own line. If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
@DJSHAMONIX : Is it the BB as a whole dropping or just the WiFi connections? Do Ethernet connected devices stay working? What colours are the light sequence when it happens?
DONT NEED HELP ,just need you to admit the fault is at your end, stop fobbing people off , come clean is all you need to do , lots of loss of service claims coming your way , contract up soon so will not be renewing for sure , worst service ever and you admins are no help what so ever
Ok smarty pants , the reboots are happening to lots of customers , Broadband and mobile signal aswell , ee cant get any of there services working correctly , so stop defending the lies , ee know they at fault , ivp6 yes i said ee dont use as there not upto date like other providers ,very poor service indeed might aswell be dialup
