Showing results forΒ
ShowΒ Β onlyΒ  | Search instead forΒ
Did you mean:Β
Ee broadband wont connect to my sky box wireless any suggestions please πŸ™
Yoda2025
Try setting up Compatible WiFi on the router under Advanced > Wireless Settings & connect your device to that.
Maestro
Maestro
@Yoda2025 You need to say what EE Router that you have and are using? See link below to the EE Router range!
